Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 1:R3=0 ; x=1"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 1:R3=0 ; x=1"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 1:R3=0 ; x=1"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 1:R3=0 ; x=1"
Executions for behaviour: "0:R0=2 ; 1:R0=2 ; 1:R1=0 ; 1:R3=0 ; x=1"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 1:R3=0 ; x=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 1:R3=0 ; x=2"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 1:R3=0 ; x=2"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 1:R3=0 ; x=2"
Executions for behaviour: "0:R0=2 ; 1:R0=2 ; 1:R1=0 ; 1:R3=0 ; x=2"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 1:R3=1 ; x=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 1:R3=1 ; x=2"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 1:R3=1 ; x=2"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 1:R3=1 ; x=2"
Executions for behaviour: "0:R0=2 ; 1:R0=2 ; 1:R1=0 ; 1:R3=1 ; x=2"
ARM MOREDETOUR0195 "DpDatadW Rfe DetourR DpAddrdR DetourRW Rfe" Cycle=Rfe DetourR DpAddrdR DetourRW Rfe DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DetourR DpAddrdR DetourRW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; %x3=x; } P0 | P1 | P2 | P3 ; LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#2 | MOV R0,#1 ; EOR R1,R0,R0 | LDR R1,[%y1] | STR R0,[%y2] | STR R0,[%x3] ; ADD R1,R1,#1 | EOR R2,R1,R1 | | ; STR R1,[%y0] | LDR R3,[R2,%x1] | | ; | MOV R4,#2 | | ; | STR R4,[%x1] | | ; Observed 0:R0=0; 1:R0=1; 1:R1=0; 1:R3=0; x=1; and 0:R0=1; 1:R0=1; 1:R1=0; 1:R3=0; x=1; and 0:R0=0; 1:R0=2; 1:R1=0; 1:R3=0; x=1; and 0:R0=1; 1:R0=2; 1:R1=0; 1:R3=0; x=1; and 0:R0=2; 1:R0=2; 1:R1=0; 1:R3=0; x=1; and 0:R0=0; 1:R0=1; 1:R1=0; 1:R3=0; x=2; and 0:R0=1; 1:R0=1; 1:R1=0; 1:R3=0; x=2; and 0:R0=0; 1:R0=2; 1:R1=0; 1:R3=0; x=2; and 0:R0=1; 1:R0=2; 1:R1=0; 1:R3=0; x=2; and 0:R0=2; 1:R0=2; 1:R1=0; 1:R3=0; x=2; and 0:R0=0; 1:R0=1; 1:R1=0; 1:R3=1; x=2; and 0:R0=1; 1:R0=1; 1:R1=0; 1:R3=1; x=2; and 0:R0=0; 1:R0=2; 1:R1=0; 1:R3=1; x=2; and 0:R0=1; 1:R0=2; 1:R1=0; 1:R3=1; x=2; and 0:R0=2; 1:R0=2; 1:R1=0; 1:R3=1; x=2;
