Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 3:R0=0 ; y=1"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 3:R0=0 ; y=1"
Executions for behaviour: "0:R0=0 ; 1:R0=3 ; 1:R1=0 ; 3:R0=0 ; y=1"
Executions for behaviour: "0:R0=1 ; 1:R0=3 ; 1:R1=0 ; 3:R0=0 ; y=1"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 3:R0=2 ; y=1"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 3:R0=2 ; y=1"
Executions for behaviour: "0:R0=0 ; 1:R0=3 ; 1:R1=0 ; 3:R0=2 ; y=1"
Executions for behaviour: "0:R0=1 ; 1:R0=3 ; 1:R1=0 ; 3:R0=2 ; y=1"
Executions for behaviour: "0:R0=0 ; 1:R0=3 ; 1:R1=2 ; 3:R0=2 ; y=1"
Executions for behaviour: "0:R0=1 ; 1:R0=3 ; 1:R1=2 ; 3:R0=2 ; y=1"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 3:R0=4 ; y=1"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 3:R0=4 ; y=1"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 3:R0=0 ; y=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=0 ; y=2"
Executions for behaviour: "0:R0=0 ; 1:R0=3 ; 1:R1=0 ; 3:R0=0 ; y=2"
Executions for behaviour: "0:R0=1 ; 1:R0=3 ; 1:R1=0 ; 3:R0=0 ; y=2"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 3:R0=1 ; y=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=1 ; y=2"
Executions for behaviour: "0:R0=0 ; 1:R0=3 ; 1:R1=0 ; 3:R0=1 ; y=2"
Executions for behaviour: "0:R0=1 ; 1:R0=3 ; 1:R1=0 ; 3:R0=1 ; y=2"
Executions for behaviour: "0:R0=0 ; 1:R0=3 ; 1:R1=1 ; 3:R0=1 ; y=2"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 3:R0=4 ; y=2"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=4 ; y=2"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 3:R0=0 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=0 ; y=3"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 3:R0=0 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 3:R0=0 ; y=3"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 3:R0=1 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=1 ; y=3"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 3:R0=1 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 3:R0=1 ; y=3"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 3:R0=2 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=2 ; y=3"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 3:R0=2 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 3:R0=2 ; y=3"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 3:R0=4 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=4 ; y=3"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 3:R0=4 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 3:R0=4 ; y=3"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 3:R0=0 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=0 ; y=4"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 3:R0=0 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 3:R0=0 ; y=4"
Executions for behaviour: "0:R0=0 ; 1:R0=3 ; 1:R1=0 ; 3:R0=0 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=3 ; 1:R1=0 ; 3:R0=0 ; y=4"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 3:R0=1 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=1 ; y=4"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 3:R0=1 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 3:R0=1 ; y=4"
Executions for behaviour: "0:R0=0 ; 1:R0=3 ; 1:R1=0 ; 3:R0=1 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=3 ; 1:R1=0 ; 3:R0=1 ; y=4"
Executions for behaviour: "0:R0=0 ; 1:R0=3 ; 1:R1=1 ; 3:R0=1 ; y=4"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 3:R0=2 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R1=0 ; 3:R0=2 ; y=4"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 3:R0=2 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 3:R0=2 ; y=4"
Executions for behaviour: "0:R0=0 ; 1:R0=3 ; 1:R1=0 ; 3:R0=2 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=3 ; 1:R1=0 ; 3:R0=2 ; y=4"
Executions for behaviour: "0:R0=0 ; 1:R0=3 ; 1:R1=2 ; 3:R0=2 ; y=4"
Executions for behaviour: "0:R0=1 ; 1:R0=3 ; 1:R1=2 ; 3:R0=2 ; y=4"
ARM MOREDETOUR0165 "DpDatadW Rfe DetourR DetourRW PodWW Rfe" Cycle=Rfe DetourR DetourRW PodWW Rfe DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DetourR DetourRW PodWW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; %y3=y; } P0 | P1 | P2 | P3 ; LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#2 | LDR R0,[%y3] ; EOR R1,R0,R0 | LDR R1,[%y1] | STR R0,[%y2] | MOV R1,#3 ; ADD R1,R1,#1 | MOV R2,#4 | | STR R1,[%y3] ; STR R1,[%y0] | STR R2,[%y1] | | ; | MOV R3,#1 | | ; | STR R3,[%x1] | | ; Observed 0:R0=0; 1:R0=2; 1:R1=0; 3:R0=0; y=1; and 0:R0=1; 1:R0=2; 1:R1=0; 3:R0=0; y=1; and 0:R0=0; 1:R0=3; 1:R1=0; 3:R0=0; y=1; and 0:R0=1; 1:R0=3; 1:R1=0; 3:R0=0; y=1; and 0:R0=0; 1:R0=2; 1:R1=0; 3:R0=2; y=1; and 0:R0=1; 1:R0=2; 1:R1=0; 3:R0=2; y=1; and 0:R0=0; 1:R0=3; 1:R1=0; 3:R0=2; y=1; and 0:R0=1; 1:R0=3; 1:R1=0; 3:R0=2; y=1; and 0:R0=0; 1:R0=3; 1:R1=2; 3:R0=2; y=1; and 0:R0=1; 1:R0=3; 1:R1=2; 3:R0=2; y=1; and 0:R0=0; 1:R0=2; 1:R1=0; 3:R0=4; y=1; and 0:R0=1; 1:R0=2; 1:R1=0; 3:R0=4; y=1; and 0:R0=0; 1:R0=1; 1:R1=0; 3:R0=0; y=2; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=0; y=2; and 0:R0=0; 1:R0=3; 1:R1=0; 3:R0=0; y=2; and 0:R0=1; 1:R0=3; 1:R1=0; 3:R0=0; y=2; and 0:R0=0; 1:R0=1; 1:R1=0; 3:R0=1; y=2; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=1; y=2; and 0:R0=0; 1:R0=3; 1:R1=0; 3:R0=1; y=2; and 0:R0=1; 1:R0=3; 1:R1=0; 3:R0=1; y=2; and 0:R0=0; 1:R0=3; 1:R1=1; 3:R0=1; y=2; and 0:R0=0; 1:R0=1; 1:R1=0; 3:R0=4; y=2; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=4; y=2; and 0:R0=0; 1:R0=1; 1:R1=0; 3:R0=0; y=3; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=0; y=3; and 0:R0=0; 1:R0=2; 1:R1=0; 3:R0=0; y=3; and 0:R0=1; 1:R0=2; 1:R1=0; 3:R0=0; y=3; and 0:R0=0; 1:R0=1; 1:R1=0; 3:R0=1; y=3; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=1; y=3; and 0:R0=0; 1:R0=2; 1:R1=0; 3:R0=1; y=3; and 0:R0=1; 1:R0=2; 1:R1=0; 3:R0=1; y=3; and 0:R0=0; 1:R0=1; 1:R1=0; 3:R0=2; y=3; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=2; y=3; and 0:R0=0; 1:R0=2; 1:R1=0; 3:R0=2; y=3; and 0:R0=1; 1:R0=2; 1:R1=0; 3:R0=2; y=3; and 0:R0=0; 1:R0=1; 1:R1=0; 3:R0=4; y=3; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=4; y=3; and 0:R0=0; 1:R0=2; 1:R1=0; 3:R0=4; y=3; and 0:R0=1; 1:R0=2; 1:R1=0; 3:R0=4; y=3; and 0:R0=0; 1:R0=1; 1:R1=0; 3:R0=0; y=4; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=0; y=4; and 0:R0=0; 1:R0=2; 1:R1=0; 3:R0=0; y=4; and 0:R0=1; 1:R0=2; 1:R1=0; 3:R0=0; y=4; and 0:R0=0; 1:R0=3; 1:R1=0; 3:R0=0; y=4; and 0:R0=1; 1:R0=3; 1:R1=0; 3:R0=0; y=4; and 0:R0=0; 1:R0=1; 1:R1=0; 3:R0=1; y=4; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=1; y=4; and 0:R0=0; 1:R0=2; 1:R1=0; 3:R0=1; y=4; and 0:R0=1; 1:R0=2; 1:R1=0; 3:R0=1; y=4; and 0:R0=0; 1:R0=3; 1:R1=0; 3:R0=1; y=4; and 0:R0=1; 1:R0=3; 1:R1=0; 3:R0=1; y=4; and 0:R0=0; 1:R0=3; 1:R1=1; 3:R0=1; y=4; and 0:R0=0; 1:R0=1; 1:R1=0; 3:R0=2; y=4; and 0:R0=1; 1:R0=1; 1:R1=0; 3:R0=2; y=4; and 0:R0=0; 1:R0=2; 1:R1=0; 3:R0=2; y=4; and 0:R0=1; 1:R0=2; 1:R1=0; 3:R0=2; y=4; and 0:R0=0; 1:R0=3; 1:R1=0; 3:R0=2; y=4; and 0:R0=1; 1:R0=3; 1:R1=0; 3:R0=2; y=4; and 0:R0=0; 1:R0=3; 1:R1=2; 3:R0=2; y=4; and 0:R0=1; 1:R0=3; 1:R1=2; 3:R0=2; y=4;
