Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 1:R3=1 ; y=1"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 1:R3=3 ; y=1"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 1:R3=3 ; y=1"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 1:R3=2 ; y=2"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 1:R3=3 ; y=2"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 1:R3=3 ; y=3"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 1:R3=3 ; y=3"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 1:R3=3 ; y=3"
ARM LB+data+detr-fri-rfi-ctrl
"DpDatadW Rfe DetourR Fri Rfi DpCtrldW Rfe"
Cycle=Rfi DpCtrldW Rfe DpDatadW Rfe DetourR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe DetourR Fri Rfi DpCtrldW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
P0 | P1 | P2 ;
LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#2 ;
EOR R1,R0,R0 | LDR R1,[%y1] | STR R0,[%y2] ;
ADD R1,R1,#1 | MOV R2,#3 | ;
STR R1,[%y0] | STR R2,[%y1] | ;
| LDR R3,[%y1] | ;
| CMP R3,R3 | ;
| BNE LC00 | ;
| LC00: | ;
| MOV R4,#1 | ;
| STR R4,[%x1] | ;
Observed
0:R0=0; 1:R0=2; 1:R1=0; 1:R3=1; y=1;
and 0:R0=0; 1:R0=2; 1:R1=0; 1:R3=3; y=1;
and 0:R0=1; 1:R0=2; 1:R1=0; 1:R3=3; y=1;
and 0:R0=0; 1:R0=1; 1:R1=0; 1:R3=2; y=2;
and 0:R0=0; 1:R0=1; 1:R1=0; 1:R3=3; y=2;
and 0:R0=0; 1:R0=1; 1:R1=0; 1:R3=3; y=3;
and 0:R0=0; 1:R0=2; 1:R1=0; 1:R3=3; y=3;
and 0:R0=1; 1:R0=2; 1:R1=0; 1:R3=3; y=3;
