Executions for behaviour: "1:R0=1 ; 1:R1=0 ; x=1"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; x=1"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; x=2"
ARM DETOUR1144 "DMBdWW Rfe DetourR DpAddrdR DpCtrldW Wse" Cycle=Rfe DetourR DpAddrdR DpCtrldW Wse DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe DetourR DpAddrdR DpCtrldW Wse { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; %y2=y; } P0 | P1 | P2 ; MOV R0,#2 | LDR R0,[%y1] | MOV R0,#2 ; STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%y2] ; DMB | EOR R2,R1,R1 | ; MOV R1,#1 | LDR R3,[R2,%z1] | ; STR R1,[%y0] | CMP R3,R3 | ; | BNE LC00 | ; | LC00: | ; | MOV R4,#1 | ; | STR R4,[%x1] | ; Observed 1:R0=1; 1:R1=0; x=1; and 1:R0=2; 1:R1=0; x=1; and 1:R0=2; 1:R1=0; x=2;
