Executions for behaviour: "0:R2=1 ; 1:R1=2 ; 1:R3=1 ; 1:R4=0 ; x=1"
Executions for behaviour: "0:R2=2 ; 1:R1=2 ; 1:R3=1 ; 1:R4=0 ; x=1"
Executions for behaviour: "0:R2=3 ; 1:R1=2 ; 1:R3=1 ; 1:R4=0 ; x=1"
Executions for behaviour: "0:R2=1 ; 1:R1=2 ; 1:R3=2 ; 1:R4=0 ; x=1"
Executions for behaviour: "0:R2=2 ; 1:R1=2 ; 1:R3=2 ; 1:R4=0 ; x=1"
Executions for behaviour: "0:R2=3 ; 1:R1=2 ; 1:R3=2 ; 1:R4=0 ; x=1"
Executions for behaviour: "0:R2=1 ; 1:R1=2 ; 1:R3=1 ; 1:R4=2 ; x=1"
Executions for behaviour: "0:R2=2 ; 1:R1=2 ; 1:R3=1 ; 1:R4=2 ; x=1"
Executions for behaviour: "0:R2=3 ; 1:R1=2 ; 1:R3=1 ; 1:R4=2 ; x=1"
Executions for behaviour: "0:R2=1 ; 1:R1=2 ; 1:R3=1 ; 1:R4=0 ; x=2"
Executions for behaviour: "0:R2=2 ; 1:R1=2 ; 1:R3=1 ; 1:R4=0 ; x=2"
Executions for behaviour: "0:R2=3 ; 1:R1=2 ; 1:R3=1 ; 1:R4=0 ; x=2"
Executions for behaviour: "0:R2=1 ; 1:R1=2 ; 1:R3=2 ; 1:R4=0 ; x=2"
Executions for behaviour: "0:R2=2 ; 1:R1=2 ; 1:R3=2 ; 1:R4=0 ; x=2"
Executions for behaviour: "0:R2=3 ; 1:R1=2 ; 1:R3=2 ; 1:R4=0 ; x=2"
Executions for behaviour: "0:R2=1 ; 1:R1=2 ; 1:R3=2 ; 1:R4=1 ; x=2"
Executions for behaviour: "0:R2=2 ; 1:R1=2 ; 1:R3=2 ; 1:R4=1 ; x=2"
Executions for behaviour: "0:R2=3 ; 1:R1=2 ; 1:R3=2 ; 1:R4=1 ; x=2"
ARM DETOUR0949 "DMBdWW Wse DetourW DpAddrdR DetourR Fre" Cycle=Fre DMBdWW Wse DetourW DpAddrdR DetourR Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Ws Fr Orig=DMBdWW Wse DetourW DpAddrdR DetourR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; %x3=x; } P0 | P1 | P2 | P3 ; MOV R0,#2 | MOV R0,#2 | MOV R0,#3 | MOV R0,#1 ; STR R0,[%x0] | STR R0,[%y1] | STR R0,[%y2] | STR R0,[%x3] ; DMB | LDR R1,[%y1] | | ; MOV R1,#1 | EOR R2,R1,R1 | | ; STR R1,[%y0] | LDR R3,[R2,%x1] | | ; DMB | LDR R4,[%x1] | | ; LDR R2,[%y0] | | | ; Observed 0:R2=1; 1:R1=2; 1:R3=1; 1:R4=0; x=1; and 0:R2=2; 1:R1=2; 1:R3=1; 1:R4=0; x=1; and 0:R2=3; 1:R1=2; 1:R3=1; 1:R4=0; x=1; and 0:R2=1; 1:R1=2; 1:R3=2; 1:R4=0; x=1; and 0:R2=2; 1:R1=2; 1:R3=2; 1:R4=0; x=1; and 0:R2=3; 1:R1=2; 1:R3=2; 1:R4=0; x=1; and 0:R2=1; 1:R1=2; 1:R3=1; 1:R4=2; x=1; and 0:R2=2; 1:R1=2; 1:R3=1; 1:R4=2; x=1; and 0:R2=3; 1:R1=2; 1:R3=1; 1:R4=2; x=1; and 0:R2=1; 1:R1=2; 1:R3=1; 1:R4=0; x=2; and 0:R2=2; 1:R1=2; 1:R3=1; 1:R4=0; x=2; and 0:R2=3; 1:R1=2; 1:R3=1; 1:R4=0; x=2; and 0:R2=1; 1:R1=2; 1:R3=2; 1:R4=0; x=2; and 0:R2=2; 1:R1=2; 1:R3=2; 1:R4=0; x=2; and 0:R2=3; 1:R1=2; 1:R3=2; 1:R4=0; x=2; and 0:R2=1; 1:R1=2; 1:R3=2; 1:R4=1; x=2; and 0:R2=2; 1:R1=2; 1:R3=2; 1:R4=1; x=2; and 0:R2=3; 1:R1=2; 1:R3=2; 1:R4=1; x=2;
