Executions for behaviour: "1:R1=0 ; 1:R3=2 ; 1:R4=1 ; x=2 ; y=1"
Executions for behaviour: "1:R1=0 ; 1:R3=2 ; 1:R4=1 ; x=2 ; y=2"
ARM DETOUR0880 "DMBdWW Wse PodWR Fri Rfi PosRR Fre" Cycle=Rfi PosRR Fre DMBdWW Wse PodWR Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Ws Fr Orig=DMBdWW Wse PodWR Fri Rfi PosRR Fre { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#2 | MOV R0,#2 ; STR R0,[%x0] | STR R0,[%y1] ; DMB | LDR R1,[%x1] ; MOV R1,#1 | MOV R2,#1 ; STR R1,[%y0] | STR R2,[%x1] ; | LDR R3,[%x1] ; | LDR R4,[%x1] ; Observed 1:R1=0; 1:R3=2; 1:R4=1; x=2; y=1; and 1:R1=0; 1:R3=2; 1:R4=1; x=2; y=2;
