Executions for behaviour: "1:R0=0 ; 1:R3=2 ; 1:R4=1 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R3=2 ; 1:R4=1 ; x=2"
Executions for behaviour: "1:R0=0 ; 1:R3=3 ; 1:R4=1 ; x=2"
Executions for behaviour: "1:R0=0 ; 1:R3=2 ; 1:R4=1 ; x=3"
Executions for behaviour: "1:R0=0 ; 1:R3=3 ; 1:R4=1 ; x=3"
ARM DETOUR0809 "DMBdWW Rfe DpAddrdW PosWR DetourR Fre" Cycle=Rfe DpAddrdW PosWR DetourR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DpAddrdW PosWR DetourR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; } P0 | P1 | P2 ; MOV R0,#3 | LDR R0,[%y1] | MOV R0,#2 ; STR R0,[%x0] | EOR R1,R0,R0 | STR R0,[%x2] ; DMB | MOV R2,#1 | ; MOV R1,#1 | STR R2,[R1,%x1] | ; STR R1,[%y0] | LDR R3,[%x1] | ; | LDR R4,[%x1] | ; Observed 1:R0=0; 1:R3=2; 1:R4=1; x=2; and 1:R0=1; 1:R3=2; 1:R4=1; x=2; and 1:R0=0; 1:R3=3; 1:R4=1; x=2; and 1:R0=0; 1:R3=2; 1:R4=1; x=3; and 1:R0=0; 1:R3=3; 1:R4=1; x=3;
