Executions for behaviour: "1:R0=0 ; 1:R2=2 ; 1:R3=1 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R2=2 ; 1:R3=1 ; x=2"
Executions for behaviour: "1:R0=0 ; 1:R2=3 ; 1:R3=1 ; x=2"
Executions for behaviour: "1:R0=0 ; 1:R2=2 ; 1:R3=1 ; x=3"
Executions for behaviour: "1:R0=0 ; 1:R2=3 ; 1:R3=1 ; x=3"
ARM DETOUR0715 "DMBdWW Rfe DpCtrldW DetourW PosRR Fre" Cycle=Rfe DpCtrldW DetourW PosRR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DpCtrldW DetourW PosRR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; } P0 | P1 | P2 ; MOV R0,#3 | LDR R0,[%y1] | MOV R0,#2 ; STR R0,[%x0] | CMP R0,R0 | STR R0,[%x2] ; DMB | BNE LC00 | ; MOV R1,#1 | LC00: | ; STR R1,[%y0] | MOV R1,#1 | ; | STR R1,[%x1] | ; | LDR R2,[%x1] | ; | LDR R3,[%x1] | ; Observed 1:R0=0; 1:R2=2; 1:R3=1; x=2; and 1:R0=1; 1:R2=2; 1:R3=1; x=2; and 1:R0=0; 1:R2=3; 1:R3=1; x=2; and 1:R0=0; 1:R2=2; 1:R3=1; x=3; and 1:R0=0; 1:R2=3; 1:R3=1; x=3;
