Executions for behaviour: "1:R0=0 ; 1:R4=3 ; 1:R5=2 ; x=3"
ARM DETOUR0705 "DMBdWW Rfe DpAddrdW Wsi Rfi PosRR Fre" Cycle=Rfi PosRR Fre DMBdWW Rfe DpAddrdW Wsi Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DpAddrdW Wsi Rfi PosRR Fre { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#3 | LDR R0,[%y1] ; STR R0,[%x0] | EOR R1,R0,R0 ; DMB | MOV R2,#1 ; MOV R1,#1 | STR R2,[R1,%x1] ; STR R1,[%y0] | MOV R3,#2 ; | STR R3,[%x1] ; | LDR R4,[%x1] ; | LDR R5,[%x1] ; Observed 1:R0=0; 1:R4=3; 1:R5=2; x=3;
