Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R4=0"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R4=0"
Executions for behaviour: "1:R0=0 ; 1:R1=1 ; 1:R4=0"
Executions for behaviour: "1:R0=1 ; 1:R1=1 ; 1:R4=0"
Executions for behaviour: "1:R0=2 ; 1:R1=1 ; 1:R4=0"
Executions for behaviour: "1:R0=1 ; 1:R1=2 ; 1:R4=0"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R4=1"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R4=1"
ARM DETOUR0654 "DMBdWW Rfe DetourR PosRR DpAddrdR Fre" Cycle=Rfe DetourR PosRR DpAddrdR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DetourR PosRR DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%y1] | MOV R0,#2 ; STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%y2] ; DMB | LDR R2,[%y1] | ; MOV R1,#1 | EOR R3,R2,R2 | ; STR R1,[%y0] | LDR R4,[R3,%x1] | ; Observed 1:R0=1; 1:R1=0; 1:R4=0; and 1:R0=2; 1:R1=0; 1:R4=0; and 1:R0=0; 1:R1=1; 1:R4=0; and 1:R0=1; 1:R1=1; 1:R4=0; and 1:R0=2; 1:R1=1; 1:R4=0; and 1:R0=1; 1:R1=2; 1:R4=0; and 1:R0=1; 1:R1=0; 1:R4=1; and 1:R0=2; 1:R1=0; 1:R4=1;
