Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 1:R2=0"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 1:R2=0"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 1:R2=0"
Executions for behaviour: "0:R0=0 ; 1:R0=0 ; 1:R1=1 ; 1:R2=0"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=1 ; 1:R2=0"
Executions for behaviour: "0:R0=0 ; 1:R0=0 ; 1:R1=2 ; 1:R2=0"
Executions for behaviour: "0:R0=1 ; 1:R0=0 ; 1:R1=2 ; 1:R2=0"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=2 ; 1:R2=0"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=2 ; 1:R2=0"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=2 ; 1:R2=0"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 1:R2=1"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 1:R2=1"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=2 ; 1:R2=1"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 1:R2=2"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=0 ; 1:R2=2"
Executions for behaviour: "0:R0=1 ; 1:R0=2 ; 1:R1=0 ; 1:R2=2"
Executions for behaviour: "0:R0=0 ; 1:R0=2 ; 1:R1=1 ; 1:R2=2"
ARM DETOUR0233
"DpDatadW Rfe PosRR DetourR DpAddrdW Rfe"
Cycle=Rfe PosRR DetourR DpAddrdW Rfe DpDatadW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe PosRR DetourR DpAddrdW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
P0 | P1 | P2 ;
LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#2 ;
EOR R1,R0,R0 | LDR R1,[%y1] | STR R0,[%y2] ;
ADD R1,R1,#1 | LDR R2,[%y1] | ;
STR R1,[%y0] | EOR R3,R2,R2 | ;
| MOV R4,#1 | ;
| STR R4,[R3,%x1] | ;
Observed
0:R0=0; 1:R0=1; 1:R1=0; 1:R2=0;
and 0:R0=0; 1:R0=2; 1:R1=0; 1:R2=0;
and 0:R0=1; 1:R0=2; 1:R1=0; 1:R2=0;
and 0:R0=0; 1:R0=0; 1:R1=1; 1:R2=0;
and 0:R0=0; 1:R0=1; 1:R1=1; 1:R2=0;
and 0:R0=0; 1:R0=0; 1:R1=2; 1:R2=0;
and 0:R0=1; 1:R0=0; 1:R1=2; 1:R2=0;
and 0:R0=0; 1:R0=1; 1:R1=2; 1:R2=0;
and 0:R0=0; 1:R0=2; 1:R1=2; 1:R2=0;
and 0:R0=1; 1:R0=2; 1:R1=2; 1:R2=0;
and 0:R0=0; 1:R0=1; 1:R1=0; 1:R2=1;
and 0:R0=0; 1:R0=2; 1:R1=0; 1:R2=1;
and 0:R0=0; 1:R0=1; 1:R1=2; 1:R2=1;
and 0:R0=0; 1:R0=1; 1:R1=0; 1:R2=2;
and 0:R0=0; 1:R0=2; 1:R1=0; 1:R2=2;
and 0:R0=1; 1:R0=2; 1:R1=0; 1:R2=2;
and 0:R0=0; 1:R0=2; 1:R1=1; 1:R2=2;
