Executions for behaviour: "0:R0=0 ; 1:R0=0 ; 1:R2=1 ; 1:R3=0"
Executions for behaviour: "0:R0=1 ; 1:R0=0 ; 1:R2=1 ; 1:R3=0"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R2=1 ; 1:R3=0"
ARM DETOUR0232 "DpDatadW Rfe DpAddrdR DetourR DpAddrdW Rfe" Cycle=Rfe DpAddrdR DetourR DpAddrdW Rfe DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DpAddrdR DetourR DpAddrdW Rfe { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; %z2=z; } P0 | P1 | P2 ; LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#1 ; EOR R1,R0,R0 | EOR R1,R0,R0 | STR R0,[%z2] ; ADD R1,R1,#1 | LDR R2,[R1,%z1] | ; STR R1,[%y0] | LDR R3,[%z1] | ; | EOR R4,R3,R3 | ; | MOV R5,#1 | ; | STR R5,[R4,%x1] | ; Observed 0:R0=0; 1:R0=0; 1:R2=1; 1:R3=0; and 0:R0=1; 1:R0=0; 1:R2=1; 1:R3=0; and 0:R0=0; 1:R0=1; 1:R2=1; 1:R3=0;
