Executions for behaviour: "0:R1=2 ; 0:R2=1 ; 2:R0=0 ; 2:R2=0"
Executions for behaviour: "0:R1=2 ; 0:R2=1 ; 2:R0=0 ; 2:R2=1"
Executions for behaviour: "0:R1=2 ; 0:R2=1 ; 2:R0=0 ; 2:R2=2"
Executions for behaviour: "0:R1=2 ; 0:R2=1 ; 2:R0=1 ; 2:R2=2"
ARM DETOUR0095 "PosWR DetourR DpCtrldW Rfe DpAddrdR Fre" Cycle=Rfe DpAddrdR Fre PosWR DetourR DpCtrldW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=PosWR DetourR DpCtrldW Rfe DpAddrdR Fre { %x0=x; %y0=y; %x1=x; %y2=y; %x2=x; } P0 | P1 | P2 ; MOV R0,#1 | MOV R0,#2 | LDR R0,[%y2] ; STR R0,[%x0] | STR R0,[%x1] | EOR R1,R0,R0 ; LDR R1,[%x0] | | LDR R2,[R1,%x2] ; LDR R2,[%x0] | | ; CMP R2,R2 | | ; BNE LC00 | | ; LC00: | | ; MOV R3,#1 | | ; STR R3,[%y0] | | ; Observed 0:R1=2; 0:R2=1; 2:R0=0; 2:R2=0; and 0:R1=2; 0:R2=1; 2:R0=0; 2:R2=1; and 0:R1=2; 0:R2=1; 2:R0=0; 2:R2=2; and 0:R1=2; 0:R2=1; 2:R0=1; 2:R2=2;
