Executions for behaviour: "1:R0=1 ; x=2 ; y=2"
ARM S0076 "DMBdWW Rfe PosRW PosWR DpAddrdW Wse" Cycle=Rfe PosRW PosWR DpAddrdW Wse DMBdWW Relax=[Wse,DMBdWW,Rfe] Safe=PosWR PosRW DpAddrdW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe PosRW PosWR DpAddrdW Wse { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | MOV R1,#2 ; DMB | STR R1,[%y1] ; MOV R1,#1 | LDR R2,[%y1] ; STR R1,[%y0] | EOR R3,R2,R2 ; | MOV R4,#1 ; | STR R4,[R3,%x1] ; Observed 1:R0=1; x=2; y=2;
