Executions for behaviour: "1:R0=1 ; 1:R1=1 ; 1:R4=2 ; 1:R6=0 ; x=2 ; z=2"
ARM S+dmb+pos-data-wsi-rfi-addr-fri
"DMBdWW Rfe PosRR DpDatadW Wsi Rfi DpAddrdR Fri Wse"
Cycle=Rfi DpAddrdR Fri Wse DMBdWW Rfe PosRR DpDatadW Wsi
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe PosRR DpDatadW Wsi Rfi DpAddrdR Fri Wse
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
P0 | P1 ;
MOV R0,#2 | LDR R0,[%y1] ;
STR R0,[%x0] | LDR R1,[%y1] ;
DMB | EOR R2,R1,R1 ;
MOV R1,#1 | ADD R2,R2,#1 ;
STR R1,[%y0] | STR R2,[%z1] ;
| MOV R3,#2 ;
| STR R3,[%z1] ;
| LDR R4,[%z1] ;
| EOR R5,R4,R4 ;
| LDR R6,[R5,%x1] ;
| MOV R7,#1 ;
| STR R7,[%x1] ;
Observed
1:R0=1; 1:R1=1; 1:R4=2; 1:R6=0; x=2; z=2;
