Executions for behaviour: "1:R0=1 ; 1:R2=2 ; 1:R4=0 ; 1:R6=1 ; x=2 ; y=2"
ARM S+dmb+fri-rfi-addr-fri-rfi-data "DMBdWW Rfe Fri Rfi DpAddrdR Fri Rfi DpDatadW Wse" Cycle=Rfi DpAddrdR Fri Rfi DpDatadW Wse DMBdWW Rfe Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe Fri Rfi DpAddrdR Fri Rfi DpDatadW Wse { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | MOV R1,#2 ; DMB | STR R1,[%y1] ; MOV R1,#1 | LDR R2,[%y1] ; STR R1,[%y0] | EOR R3,R2,R2 ; | LDR R4,[R3,%z1] ; | MOV R5,#1 ; | STR R5,[%z1] ; | LDR R6,[%z1] ; | EOR R7,R6,R6 ; | ADD R7,R7,#1 ; | STR R7,[%x1] ; Observed 1:R0=1; 1:R2=2; 1:R4=0; 1:R6=1; x=2; y=2;
