Executions for behaviour: "1:R0=1 ; 1:R2=2 ; 1:R6=1 ; x=2 ; y=2"
ARM S+dmb+fri-rfi-addr-data-rfi-ctrl
"DMBdWW Rfe Fri Rfi DpAddrdR DpDatadW Rfi DpCtrldW Wse"
Cycle=Rfi DpAddrdR DpDatadW Rfi DpCtrldW Wse DMBdWW Rfe Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe Fri Rfi DpAddrdR DpDatadW Rfi DpCtrldW Wse
%x0=x; %y0=y;
%y1=y; %z1=z; %a1=a; %x1=x;
P0 | P1 ;
MOV R0,#2 | LDR R0,[%y1] ;
STR R0,[%x0] | MOV R1,#2 ;
DMB | STR R1,[%y1] ;
MOV R1,#1 | LDR R2,[%y1] ;
STR R1,[%y0] | EOR R3,R2,R2 ;
| LDR R4,[R3,%z1] ;
| EOR R5,R4,R4 ;
| ADD R5,R5,#1 ;
| STR R5,[%a1] ;
| LDR R6,[%a1] ;
| CMP R6,R6 ;
| BNE LC00 ;
| LC00: ;
| MOV R7,#1 ;
| STR R7,[%x1] ;
Observed
1:R0=1; 1:R2=2; 1:R6=1; x=2; y=2;
