Executions for behaviour: "1:R0=1 ; 1:R3=2 ; 1:R5=0 ; 1:R6=0 ; x=2 ; z=2"
ARM S+dmb+data-wsi-rfi-addr-pos-fri
"DMBdWW Rfe DpDatadW Wsi Rfi DpAddrdR PosRR Fri Wse"
Cycle=Rfi DpAddrdR PosRR Fri Wse DMBdWW Rfe DpDatadW Wsi
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe DpDatadW Wsi Rfi DpAddrdR PosRR Fri Wse
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
P0 | P1 ;
MOV R0,#2 | LDR R0,[%y1] ;
STR R0,[%x0] | EOR R1,R0,R0 ;
DMB | ADD R1,R1,#1 ;
MOV R1,#1 | STR R1,[%z1] ;
STR R1,[%y0] | MOV R2,#2 ;
| STR R2,[%z1] ;
| LDR R3,[%z1] ;
| EOR R4,R3,R3 ;
| LDR R5,[R4,%x1] ;
| LDR R6,[%x1] ;
| MOV R7,#1 ;
| STR R7,[%x1] ;
Observed
1:R0=1; 1:R3=2; 1:R5=0; 1:R6=0; x=2; z=2;
