Executions for behaviour: "1:R0=1 ; x=2 ; y=2"
ARM S+PPO756 "Wse DMBdWW Rfe PosRW PosWR DpCtrldW" Cycle=Rfe PosRW PosWR DpCtrldW Wse DMBdWW Relax= Safe=Rfe Wse PosWR PosRW DMBdWW DpCtrldW Prefetch=0:x=F,1:x=W Orig=Wse DMBdWW Rfe PosRW PosWR DpCtrldW { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | MOV R1, #2 ; DMB | STR R1, [%y1] ; MOV R1, #1 | LDR R2, [%y1] ; STR R1, [%y0] | CMP R2, R2 ; | BNE LC00 ; | LC00: ; | MOV R3, #1 ; | STR R3, [%x1] ; Observed 1:R0=1; x=2; y=2;
