Executions for behaviour: "1:R0=1 ; a=2 ; x=2"
ARM S+PPO728
"Wse DMBdWW Rfe PosRR DpAddrdR DpAddrdW PosWW PosWR DpCtrldW"
Cycle=Rfe PosRR DpAddrdR DpAddrdW PosWW PosWR DpCtrldW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWW PosWR PosRR DMBdWW DpAddrdW DpAddrdR DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRR DpAddrdR DpAddrdW PosWW PosWR DpCtrldW
%x0=x; %y0=y;
%y1=y; %z1=z; %a1=a; %x1=x;
 P0            | P1               ;
 MOV R0, #2    | LDR R0, [%y1]    ;
 STR R0, [%x0] | LDR R1, [%y1]    ;
 DMB           | EOR R2,R1,R1     ;
 MOV R1, #1    | LDR R3, [R2,%z1] ;
 STR R1, [%y0] | EOR R4,R3,R3     ;
               | MOV R5, #1       ;
               | STR R5, [R4,%a1] ;
               | MOV R6, #2       ;
               | STR R6, [%a1]    ;
               | LDR R7, [%a1]    ;
               | CMP R7, R7       ;
               | BNE LC00         ;
               | LC00:            ;
               | MOV R8, #1       ;
               | STR R8, [%x1]    ;
Observed
    1:R0=1; a=2; x=2;
