Executions for behaviour: "1:R0=1 ; 1:R4=1 ; x=2"
ARM MP+PPO955 "Fre DMBdWW Rfe PosRR DpCtrldW PosWR PosRR" Cycle=Rfe PosRR DpCtrldW PosWR PosRR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRR DMBdWW DpCtrldW Prefetch=1:x=T Orig=Fre DMBdWW Rfe PosRR DpCtrldW PosWR PosRR { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | CMP R1, R1 ; MOV R1, #1 | BNE LC00 ; STR R1, [%y0] | LC00: ; | MOV R2, #1 ; | STR R2, [%x1] ; | LDR R3, [%x1] ; | LDR R4, [%x1] ; Observed 1:R0=1; 1:R4=1; x=2;
