Executions for behaviour: "1:R0=1 ; 1:R3=1 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R3=2 ; x=2"
ARM MP+PPO750
"Fre DMBdWW Rfe PosRR DpCtrldW PosWR"
Cycle=Rfe PosRR DpCtrldW PosWR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWR PosRR DMBdWW DpCtrldW
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRR DpCtrldW PosWR
%x0=x; %y0=y;
%y1=y; %x1=x;
P0 | P1 ;
MOV R0, #2 | LDR R0, [%y1] ;
STR R0, [%x0] | LDR R1, [%y1] ;
DMB | CMP R1, R1 ;
MOV R1, #1 | BNE LC00 ;
STR R1, [%y0] | LC00: ;
| MOV R2, #1 ;
| STR R2, [%x1] ;
| LDR R3, [%x1] ;
Observed
1:R0=1; 1:R3=1; x=2;
and 1:R0=1; 1:R3=2; x=2;
