Test MOREDETOUR0829
Executions for behaviour: "1:R0=1 ; 2:R0=0 ; 2:R2=2 ; x=4"
Executions for behaviour: "1:R0=1 ; 2:R0=0 ; 2:R2=4 ; x=4"
ARM MOREDETOUR0829
"DMBdWW Rfe PosRR DpAddrdW DetourWW Wse"
Cycle=Rfe PosRR DpAddrdW DetourWW Wse DMBdWW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe PosRR DpAddrdW DetourWW Wse
%x0=x; %y0=y;
%y1=y; %x1=x;
%x2=x;
 P0           | P1              | P2           ;
 MOV R0,#4    | LDR R0,[%y1]    | LDR R0,[%x2] ;
 STR R0,[%x0] | LDR R1,[%y1]    | MOV R1,#2    ;
 DMB          | EOR R2,R1,R1    | STR R1,[%x2] ;
 MOV R1,#1    | MOV R3,#1       | DMB          ;
 STR R1,[%y0] | STR R3,[R2,%x1] | LDR R2,[%x2] ;
              | MOV R4,#3       |              ;
              | STR R4,[%x1]    |              ;
Observed
    1:R0=1; 2:R0=0; 2:R2=2; x=4;
and 1:R0=1; 2:R0=0; 2:R2=4; x=4;
