Executions for behaviour: "1:R1=1 ; 1:R4=0 ; y=1"
ARM DETOUR0836 "DMBdWW Wse Rfi PosRR DpAddrdR Fre" Cycle=Rfi PosRR DpAddrdR Fre DMBdWW Wse Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Ws Fr Orig=DMBdWW Wse Rfi PosRR DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#1 | MOV R0,#2 ; STR R0,[%x0] | STR R0,[%y1] ; DMB | LDR R1,[%y1] ; MOV R1,#1 | LDR R2,[%y1] ; STR R1,[%y0] | EOR R3,R2,R2 ; | LDR R4,[R3,%x1] ; Observed 1:R1=1; 1:R4=0; y=1;
