Executions for behaviour: "1:R0=1 ; 1:R3=0 ; 1:R4=0 ; x=1"
Executions for behaviour: "1:R0=1 ; 1:R3=0 ; 1:R4=1 ; x=1"
Executions for behaviour: "1:R0=1 ; 1:R3=0 ; 1:R4=2 ; x=1"
Executions for behaviour: "1:R0=1 ; 1:R3=0 ; 1:R4=0 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R3=1 ; 1:R4=1 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R3=0 ; 1:R4=2 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R3=1 ; 1:R4=2 ; x=2"
ARM DETOUR0806
"DMBdWW Rfe PosRR DpAddrdR DetourR Fre"
Cycle=Rfe PosRR DpAddrdR DetourR Fre DMBdWW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe PosRR DpAddrdR DetourR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
%x2=x;
P0 | P1 | P2 ;
MOV R0,#2 | LDR R0,[%y1] | MOV R0,#1 ;
STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%x2] ;
DMB | EOR R2,R1,R1 | ;
MOV R1,#1 | LDR R3,[R2,%x1] | ;
STR R1,[%y0] | LDR R4,[%x1] | ;
Observed
1:R0=1; 1:R3=0; 1:R4=0; x=1;
and 1:R0=1; 1:R3=0; 1:R4=1; x=1;
and 1:R0=1; 1:R3=0; 1:R4=2; x=1;
and 1:R0=1; 1:R3=0; 1:R4=0; x=2;
and 1:R0=1; 1:R3=1; 1:R4=1; x=2;
and 1:R0=1; 1:R3=0; 1:R4=2; x=2;
and 1:R0=1; 1:R3=1; 1:R4=2; x=2;
