Executions for behaviour: "1:R0=1 ; 1:R3=1 ; x=3"
ARM DETOUR0771 "DMBdWW Rfe PosRR DpDatadW DetourW Fre" Cycle=Rfe PosRR DpDatadW DetourW Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe PosRR DpDatadW DetourW Fre { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; } P0 | P1 | P2 ; MOV R0,#3 | LDR R0,[%y1] | MOV R0,#2 ; STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%x2] ; DMB | EOR R2,R1,R1 | ; MOV R1,#1 | ADD R2,R2,#1 | ; STR R1,[%y0] | STR R2,[%x1] | ; | LDR R3,[%x1] | ; Observed 1:R0=1; 1:R3=1; x=3;
