Executions for behaviour: "1:R0=1 ; 1:R1=2 ; 1:R4=1 ; x=2"
ARM DETOUR0697 "DMBdWW Rfe DetourR DpAddrdW PosWR Fre" Cycle=Rfe DetourR DpAddrdW PosWR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DetourR DpAddrdW PosWR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; } P0 | P1 | P2 ; MOV R0,#2 | LDR R0,[%y1] | MOV R0,#2 ; STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%y2] ; DMB | EOR R2,R1,R1 | ; MOV R1,#1 | MOV R3,#1 | ; STR R1,[%y0] | STR R3,[R2,%x1] | ; | LDR R4,[%x1] | ; Observed 1:R0=1; 1:R1=2; 1:R4=1; x=2;
