Executions for behaviour: "1:R0=1 ; 1:R1=1 ; 1:R3=0"
Executions for behaviour: "1:R0=1 ; 1:R1=2 ; 1:R3=0"
ARM DETOUR0661 "DMBdWW Rfe DetourR DpAddrdR Fre" Cycle=Rfe DetourR DpAddrdR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DetourR DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%y1] | MOV R0,#2 ; STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%y2] ; DMB | EOR R2,R1,R1 | ; MOV R1,#1 | LDR R3,[R2,%x1] | ; STR R1,[%y0] | | ; Observed 1:R0=1; 1:R1=1; 1:R3=0; and 1:R0=1; 1:R1=2; 1:R3=0;
