Executions for behaviour:
"1:R0=1 ; x=2 ; z=2"
ARM S+PPO885
"Wse DMBdWW Rfe PosRR DpCtrldW PosWW PosWR DpAddrdR PosRW"
Cycle=Rfe PosRR DpCtrldW PosWW PosWR DpAddrdR PosRW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWW PosWR PosRW PosRR DMBdWW DpAddrdR DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRR DpCtrldW PosWW PosWR DpAddrdR PosRW
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
P0 | P1 ;
MOV R0, #2 | LDR R0, [%y1] ;
STR R0, [%x0] | LDR R1, [%y1] ;
DMB | CMP R1, R1 ;
MOV R1, #1 | BNE LC00 ;
STR R1, [%y0] | LC00: ;
| MOV R2, #1 ;
| STR R2, [%z1] ;
| MOV R3, #2 ;
| STR R3, [%z1] ;
| LDR R4, [%z1] ;
| EOR R5,R4,R4 ;
| LDR R6, [R5,%x1] ;
| MOV R7, #1 ;
| STR R7, [%x1] ;
Observed
1:R0=1; x=2; z=2;
