Executions for behaviour:
"1:R0=1 ; x=2"
ARM S+PPO811
"Wse DMBdWW Rfe PosRR DpAddrdW PosWR PosRR DpCtrldW"
Cycle=Rfe PosRR DpAddrdW PosWR PosRR DpCtrldW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWR PosRR DMBdWW DpAddrdW DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRR DpAddrdW PosWR PosRR DpCtrldW
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
P0 | P1 ;
MOV R0, #2 | LDR R0, [%y1] ;
STR R0, [%x0] | LDR R1, [%y1] ;
DMB | EOR R2,R1,R1 ;
MOV R1, #1 | MOV R3, #1 ;
STR R1, [%y0] | STR R3, [R2,%z1] ;
| LDR R4, [%z1] ;
| LDR R5, [%z1] ;
| CMP R5, R5 ;
| BNE LC00 ;
| LC00: ;
| MOV R6, #1 ;
| STR R6, [%x1] ;
Observed
1:R0=1; x=2;
