Executions for behaviour:
"1:R0=1 ; a=2 ; x=2"
ARM S+PPO737
"Wse DMBdWW Rfe PosRR DpAddrdR DpDatadW PosWW PosWR DpCtrldW"
Cycle=Rfe PosRR DpAddrdR DpDatadW PosWW PosWR DpCtrldW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWW PosWR PosRR DMBdWW DpAddrdR DpDatadW DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRR DpAddrdR DpDatadW PosWW PosWR DpCtrldW
%x0=x; %y0=y;
%y1=y; %z1=z; %a1=a; %x1=x;
P0 | P1 ;
MOV R0, #2 | LDR R0, [%y1] ;
STR R0, [%x0] | LDR R1, [%y1] ;
DMB | EOR R2,R1,R1 ;
MOV R1, #1 | LDR R3, [R2,%z1] ;
STR R1, [%y0] | EOR R4,R3,R3 ;
| ADD R4, R4, #1 ;
| STR R4, [%a1] ;
| MOV R5, #2 ;
| STR R5, [%a1] ;
| LDR R6, [%a1] ;
| CMP R6, R6 ;
| BNE LC00 ;
| LC00: ;
| MOV R7, #1 ;
| STR R7, [%x1] ;
Observed
1:R0=1; a=2; x=2;
