Executions for behaviour:
"1:R0=1 ; x=2"
ARM S+PPO214
"Wse DMBdWW Rfe PosRR DpAddrdW"
Cycle=Rfe PosRR DpAddrdW Wse DMBdWW
Relax=
Safe=Rfe Wse PosRR DMBdWW DpAddrdW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRR DpAddrdW
%x0=x; %y0=y;
%y1=y; %x1=x;
P0 | P1 ;
MOV R0, #2 | LDR R0, [%y1] ;
STR R0, [%x0] | LDR R1, [%y1] ;
DMB | EOR R2,R1,R1 ;
MOV R1, #1 | MOV R3, #1 ;
STR R1, [%y0] | STR R3, [R2,%x1] ;
Observed
1:R0=1; x=2;
