Executions for behaviour:
"1:R0=1 ; x=2 ; y=2 ; z=2"
ARM S+PPO166
"Wse DMBdWW Rfe PosRW PosWR DpAddrdW PosWW PosWR DpAddrdW"
Cycle=Rfe PosRW PosWR DpAddrdW PosWW PosWR DpAddrdW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWW PosWR PosRW DMBdWW DpAddrdW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRW PosWR DpAddrdW PosWW PosWR DpAddrdW
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
P0 | P1 ;
MOV R0, #2 | LDR R0, [%y1] ;
STR R0, [%x0] | MOV R1, #2 ;
DMB | STR R1, [%y1] ;
MOV R1, #1 | LDR R2, [%y1] ;
STR R1, [%y0] | EOR R3,R2,R2 ;
| MOV R4, #1 ;
| STR R4, [R3,%z1] ;
| MOV R5, #2 ;
| STR R5, [%z1] ;
| LDR R6, [%z1] ;
| EOR R7,R6,R6 ;
| MOV R8, #1 ;
| STR R8, [R7,%x1] ;
Observed
1:R0=1; x=2; y=2; z=2;
