Executions for behaviour:
"1:R0=0 ; 1:R2=1 ; 1:R3=2 ; 1:R5=1 ; 1:R6=1 ; x=1 ; y=1"
"1:R0=0 ; 1:R2=1 ; 1:R3=2 ; 1:R5=1 ; 1:R6=1 ; x=2 ; y=1"
"1:R0=0 ; 1:R2=2 ; 1:R3=2 ; 1:R5=2 ; 1:R6=1 ; x=2 ; y=1"
"1:R0=1 ; 1:R2=2 ; 1:R3=2 ; 1:R5=1 ; 1:R6=1 ; x=2 ; y=2"
"1:R0=0 ; 1:R2=2 ; 1:R3=2 ; 1:R5=2 ; 1:R6=1 ; x=2 ; y=2"
ARM MP+dmb+fri-rfi-pos-ctrl-rfi-pos
"DMBdWW Rfe Fri Rfi PosRR DpCtrldW Rfi PosRR Fre"
Cycle=Rfi PosRR Fre DMBdWW Rfe Fri Rfi PosRR DpCtrldW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe Fri Rfi PosRR DpCtrldW Rfi PosRR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
P0 | P1 ;
MOV R0,#2 | LDR R0,[%y1] ;
STR R0,[%x0] | MOV R1,#2 ;
DMB | STR R1,[%y1] ;
MOV R1,#1 | LDR R2,[%y1] ;
STR R1,[%y0] | LDR R3,[%y1] ;
| CMP R3,R3 ;
| BNE LC00 ;
| LC00: ;
| MOV R4,#1 ;
| STR R4,[%x1] ;
| LDR R5,[%x1] ;
| LDR R6,[%x1] ;
Observed
1:R0=0; 1:R2=1; 1:R3=2; 1:R5=1; 1:R6=1; x=1; y=1;
and 1:R0=0; 1:R2=1; 1:R3=2; 1:R5=1; 1:R6=1; x=2; y=1;
and 1:R0=0; 1:R2=2; 1:R3=2; 1:R5=2; 1:R6=1; x=2; y=1;
and 1:R0=1; 1:R2=2; 1:R3=2; 1:R5=1; 1:R6=1; x=2; y=2;
and 1:R0=0; 1:R2=2; 1:R3=2; 1:R5=2; 1:R6=1; x=2; y=2;
