Executions for behaviour:
"1:R0=1 ; 1:R6=1 ; x=2"
ARM MP+PPO915
"Fre DMBdWW Rfe PosRR DpDatadW PosWR DpDatadW PosWR PosRR"
Cycle=Rfe PosRR DpDatadW PosWR DpDatadW PosWR PosRR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWR PosRR DMBdWW DpDatadW
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRR DpDatadW PosWR DpDatadW PosWR PosRR
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
P0 | P1 ;
MOV R0, #2 | LDR R0, [%y1] ;
STR R0, [%x0] | LDR R1, [%y1] ;
DMB | EOR R2,R1,R1 ;
MOV R1, #1 | ADD R2, R2, #1 ;
STR R1, [%y0] | STR R2, [%z1] ;
| LDR R3, [%z1] ;
| EOR R4,R3,R3 ;
| ADD R4, R4, #1 ;
| STR R4, [%x1] ;
| LDR R5, [%x1] ;
| LDR R6, [%x1] ;
Observed
1:R0=1; 1:R6=1; x=2;
