Executions for behaviour:
"1:R0=1 ; 1:R4=0"
ARM MP+PPO849
"Fre DMBdWW Rfe PosRR DpAddrdR PosRR"
Cycle=Rfe PosRR DpAddrdR PosRR Fre DMBdWW
Relax=
Safe=Rfe Fre PosRR DMBdWW DpAddrdR
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRR DpAddrdR PosRR
%x0=x; %y0=y;
%y1=y; %x1=x;
P0 | P1 ;
MOV R0, #1 | LDR R0, [%y1] ;
STR R0, [%x0] | LDR R1, [%y1] ;
DMB | EOR R2,R1,R1 ;
MOV R1, #1 | LDR R3, [R2,%x1] ;
STR R1, [%y0] | LDR R4, [%x1] ;
Observed
1:R0=1; 1:R4=0;
