Executions for behaviour:
"1:R0=1 ; 1:R7=1 ; x=2 ; z=2"
"1:R0=1 ; 1:R7=2 ; x=2 ; z=2"
ARM MP+PPO584
"Fre DMBdWW Rfe DpDatadW PosWW PosWR PosRR DpAddrdW PosWR"
Cycle=Rfe DpDatadW PosWW PosWR PosRR DpAddrdW PosWR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWW PosWR PosRR DMBdWW DpAddrdW DpDatadW
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe DpDatadW PosWW PosWR PosRR DpAddrdW PosWR
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
P0 | P1 ;
MOV R0, #2 | LDR R0, [%y1] ;
STR R0, [%x0] | EOR R1,R0,R0 ;
DMB | ADD R1, R1, #1 ;
MOV R1, #1 | STR R1, [%z1] ;
STR R1, [%y0] | MOV R2, #2 ;
| STR R2, [%z1] ;
| LDR R3, [%z1] ;
| LDR R4, [%z1] ;
| EOR R5,R4,R4 ;
| MOV R6, #1 ;
| STR R6, [R5,%x1] ;
| LDR R7, [%x1] ;
Observed
1:R0=1; 1:R7=1; x=2; z=2;
and 1:R0=1; 1:R7=2; x=2; z=2;
