Executions for behaviour:
"1:R0=1 ; 1:R8=1 ; x=2 ; y=2"
"1:R0=1 ; 1:R8=2 ; x=2 ; y=2"
ARM MP+PPO571
"Fre DMBdWW Rfe PosRW PosWR DpAddrdR PosRR DpAddrdW PosWR"
Cycle=Rfe PosRW PosWR DpAddrdR PosRR DpAddrdW PosWR Fre DMBdWW
Relax=
Safe=Rfe Fre PosWR PosRW PosRR DMBdWW DpAddrdW DpAddrdR
Prefetch=1:x=T
Orig=Fre DMBdWW Rfe PosRW PosWR DpAddrdR PosRR DpAddrdW PosWR
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
P0 | P1 ;
MOV R0, #2 | LDR R0, [%y1] ;
STR R0, [%x0] | MOV R1, #2 ;
DMB | STR R1, [%y1] ;
MOV R1, #1 | LDR R2, [%y1] ;
STR R1, [%y0] | EOR R3,R2,R2 ;
| LDR R4, [R3,%z1] ;
| LDR R5, [%z1] ;
| EOR R6,R5,R5 ;
| MOV R7, #1 ;
| STR R7, [R6,%x1] ;
| LDR R8, [%x1] ;
Observed
1:R0=1; 1:R8=1; x=2; y=2;
and 1:R0=1; 1:R8=2; x=2; y=2;
