Executions for behaviour:
"0:R0=0 ; 1:R0=0 ; 1:R1=0 ; 1:R3=1 ; 1:R4=2 ; y=1"
"0:R0=1 ; 1:R0=0 ; 1:R1=0 ; 1:R3=1 ; 1:R4=2 ; y=1"
"0:R0=0 ; 1:R0=1 ; 1:R1=0 ; 1:R3=2 ; 1:R4=2 ; y=2"
"0:R0=1 ; 1:R0=1 ; 1:R1=1 ; 1:R3=2 ; 1:R4=2 ; y=2"
ARM LB+data+pos-fri-rfi-pos-addr-po
"DpDatadW Rfe PosRR Fri Rfi PosRR DpAddrdR PodRW Rfe"
Cycle=Rfi PosRR DpAddrdR PodRW Rfe DpDatadW Rfe PosRR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe PosRR Fri Rfi PosRR DpAddrdR PodRW Rfe
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
P0 | P1 ;
LDR R0,[%x0] | LDR R0,[%y1] ;
EOR R1,R0,R0 | LDR R1,[%y1] ;
ADD R1,R1,#1 | MOV R2,#2 ;
STR R1,[%y0] | STR R2,[%y1] ;
| LDR R3,[%y1] ;
| LDR R4,[%y1] ;
| EOR R5,R4,R4 ;
| LDR R6,[R5,%z1] ;
| MOV R7,#1 ;
| STR R7,[%x1] ;
Observed
0:R0=0; 1:R0=0; 1:R1=0; 1:R3=1; 1:R4=2; y=1;
and 0:R0=1; 1:R0=0; 1:R1=0; 1:R3=1; 1:R4=2; y=1;
and 0:R0=0; 1:R0=1; 1:R1=0; 1:R3=2; 1:R4=2; y=2;
and 0:R0=1; 1:R0=1; 1:R1=1; 1:R3=2; 1:R4=2; y=2;
