Executions for behaviour:
"0:R0=1 ; 1:R0=1"
ARM LB+PPO0489
"PodRW Rfe DpDatadW Rfe PosRR DpAddrdR PosRW PosWR"
Cycle=Rfe PosRR DpAddrdR PosRW PosWR PodRW Rfe DpDatadW
Relax=
Safe=Rfe PosWR PosRW PosRR Pod*W DpAddrdR DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe PosRR DpAddrdR PosRW PosWR
%z0=z; %x0=x;
%x1=x; %y1=y; %z1=z;
P0 | P1 ;
LDR R0,[%z0] | LDR R0,[%x1] ;
EOR R1,R0,R0 | LDR R1,[%x1] ;
ADD R1,R1,#1 | EOR R2,R1,R1 ;
STR R1,[%x0] | LDR R3,[R2,%y1] ;
| MOV R4,#1 ;
| STR R4,[%y1] ;
| LDR R5,[%y1] ;
| MOV R6,#1 ;
| STR R6,[%z1] ;
Observed
0:R0=1; 1:R0=1;
