Executions for behaviour:
"0:R0=1 ; 1:R0=1 ; z=2"
ARM LB+PPO0471
"PodRW Rfe DpDatadW Rfe PosRR DpAddrdR DpDatadW PosWW PosWR"
Cycle=Rfe PosRR DpAddrdR DpDatadW PosWW PosWR PodRW Rfe DpDatadW
Relax=
Safe=Rfe PosWW PosWR PosRR Pod*W DpAddrdR DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe PosRR DpAddrdR DpDatadW PosWW PosWR
%a0=a; %x0=x;
%x1=x; %y1=y; %z1=z; %a1=a;
P0 | P1 ;
LDR R0,[%a0] | LDR R0,[%x1] ;
EOR R1,R0,R0 | LDR R1,[%x1] ;
ADD R1,R1,#1 | EOR R2,R1,R1 ;
STR R1,[%x0] | LDR R3,[R2,%y1] ;
| EOR R4,R3,R3 ;
| ADD R4,R4,#1 ;
| STR R4,[%z1] ;
| MOV R5,#2 ;
| STR R5,[%z1] ;
| LDR R6,[%z1] ;
| MOV R7,#1 ;
| STR R7,[%a1] ;
Observed
0:R0=1; 1:R0=1; z=2;
