Executions for behaviour:
"0:R0=1 ; 1:R0=1"
ARM LB+PPO0455
"PodRW Rfe DpDatadW Rfe PosRR DpCtrldW PosWR"
Cycle=Rfe PosRR DpCtrldW PosWR PodRW Rfe DpDatadW
Relax=
Safe=Rfe PosWR PosRR Pod*W DpDatadW DpCtrldW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe PosRR DpCtrldW PosWR
%z0=z; %x0=x;
%x1=x; %y1=y; %z1=z;
P0 | P1 ;
LDR R0,[%z0] | LDR R0,[%x1] ;
EOR R1,R0,R0 | LDR R1,[%x1] ;
ADD R1,R1,#1 | CMP R1,R1 ;
STR R1,[%x0] | BNE LC00 ;
| LC00: ;
| MOV R2,#1 ;
| STR R2,[%y1] ;
| LDR R3,[%y1] ;
| MOV R4,#1 ;
| STR R4,[%z1] ;
Observed
0:R0=1; 1:R0=1;
