Executions for behaviour:
"1:R0=1 ; 1:R2=0 ; x=1"
ARM WRR+2W+addr+dmb "Rfe DpAddrdR Fre DMBdWW Wse" Cycle=Rfe DpAddrdR Fre DMBdWW Wse Prefetch=0:x=F,1:x=F,1:y=T,2:y=F,2:x=W Com=Rf Fr Ws Orig=Rfe DpAddrdR Fre DMBdWW Wse { %x0=x; %x1=x; %y1=y; %y2=y; %x2=x; } P0 | P1 | P2 ; MOV R0,#2 | LDR R0,[%x1] | MOV R0,#1 ; STR R0,[%x0] | EOR R1,R0,R0 | STR R0,[%y2] ; | LDR R2,[R1,%y1] | DMB ; | | MOV R1,#1 ; | | STR R1,[%x2] ; Observed 1:R0=1; 1:R2=0; x=1;
