Executions for behaviour:
"0:R0=64 ; 1:R0=0"
ARM LB+PPO0536 "PodRW Rfe DpDatadW Rfe DpAddrdR PosRR" Cycle=Rfe DpAddrdR PosRR PodRW Rfe DpDatadW Relax= Safe=Rfe PosRR Pod*W DpAddrdR DpDatadW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe DpAddrdR PosRR { %z0=z; %x0=x; %x1=x; %y1=y; %z1=z; } P0 | P1 ; LDR R0,[%z0] | LDR R0,[%x1] ; EOR R1,R0,R0 | EOR R1,R0,R0 ; ADD R1,R1,#1 | LDR R2,[R1,%y1] ; STR R1,[%x0] | LDR R3,[%y1] ; | MOV R4,#1 ; | STR R4,[%z1] ; Observed 0:R0=64; 1:R0=0;
