Test S+PPO847
Executions for behaviour: "1:R0=1 ; x=2 ; y=2"
ARM S+PPO847
"Wse DMBdWW Rfe PosRR PosRW PosWR PosRR DpCtrldW"
Cycle=Rfe PosRR PosRW PosWR PosRR DpCtrldW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWR PosRW PosRR DMBdWW DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRR PosRW PosWR PosRR DpCtrldW
%x0=x; %y0=y;
%y1=y; %x1=x;
 P0            | P1            ;
 MOV R0, #2    | LDR R0, [%y1] ;
 STR R0, [%x0] | LDR R1, [%y1] ;
 DMB           | MOV R2, #2    ;
 MOV R1, #1    | STR R2, [%y1] ;
 STR R1, [%y0] | LDR R3, [%y1] ;
               | LDR R4, [%y1] ;
               | CMP R4, R4    ;
               | BNE LC00      ;
               | LC00:         ;
               | MOV R5, #1    ;
               | STR R5, [%x1] ;
Observed
    1:R0=1; x=2; y=2;
