Executions for behaviour:
"1:R0=1 ; x=2 ; z=2"
ARM S+PPO836 "Wse DMBdWW Rfe PosRR DpDatadW PosWW PosWR PosRR DpCtrldW" Cycle=Rfe PosRR DpDatadW PosWW PosWR PosRR DpCtrldW Wse DMBdWW Relax= Safe=Rfe Wse PosWW PosWR PosRR DMBdWW DpDatadW DpCtrldW Prefetch=0:x=F,1:x=W Orig=Wse DMBdWW Rfe PosRR DpDatadW PosWW PosWR PosRR DpCtrldW { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | EOR R2,R1,R1 ; MOV R1, #1 | ADD R2, R2, #1 ; STR R1, [%y0] | STR R2, [%z1] ; | MOV R3, #2 ; | STR R3, [%z1] ; | LDR R4, [%z1] ; | LDR R5, [%z1] ; | CMP R5, R5 ; | BNE LC00 ; | LC00: ; | MOV R6, #1 ; | STR R6, [%x1] ; Observed 1:R0=1; x=2; z=2;
