Test S+PPO688
Executions for behaviour: "1:R0=1 ; x=2 ; y=2"
ARM S+PPO688
"Wse DMBdWW Rfe PosRR PosRW PosWR DpDatadW PosWR DpCtrldW"
Cycle=Rfe PosRR PosRW PosWR DpDatadW PosWR DpCtrldW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWR PosRW PosRR DMBdWW DpDatadW DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRR PosRW PosWR DpDatadW PosWR DpCtrldW
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0            | P1             ;
 MOV R0, #2    | LDR R0, [%y1]  ;
 STR R0, [%x0] | LDR R1, [%y1]  ;
 DMB           | MOV R2, #2     ;
 MOV R1, #1    | STR R2, [%y1]  ;
 STR R1, [%y0] | LDR R3, [%y1]  ;
               | EOR R4,R3,R3   ;
               | ADD R4, R4, #1 ;
               | STR R4, [%z1]  ;
               | LDR R5, [%z1]  ;
               | CMP R5, R5     ;
               | BNE LC00       ;
               | LC00:          ;
               | MOV R6, #1     ;
               | STR R6, [%x1]  ;
Observed
    1:R0=1; x=2; y=2;
