Test S+PPO346
Executions for behaviour: "1:R0=1 ; x=2"
ARM S+PPO346
"Wse DMBdWW Rfe PosRR DpCtrldW PosWR PosRR DpAddrdR DpDatadW"
Cycle=Rfe PosRR DpCtrldW PosWR PosRR DpAddrdR DpDatadW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWR PosRR DMBdWW DpAddrdR DpDatadW DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRR DpCtrldW PosWR PosRR DpAddrdR DpDatadW
%x0=x; %y0=y;
%y1=y; %z1=z; %a1=a; %x1=x;
 P0            | P1               ;
 MOV R0, #2    | LDR R0, [%y1]    ;
 STR R0, [%x0] | LDR R1, [%y1]    ;
 DMB           | CMP R1, R1       ;
 MOV R1, #1    | BNE LC00         ;
 STR R1, [%y0] | LC00:            ;
               | MOV R2, #1       ;
               | STR R2, [%z1]    ;
               | LDR R3, [%z1]    ;
               | LDR R4, [%z1]    ;
               | EOR R5,R4,R4     ;
               | LDR R6, [R5,%a1] ;
               | EOR R7,R6,R6     ;
               | ADD R7, R7, #1   ;
               | STR R7, [%x1]    ;
Observed
    1:R0=1; x=2;
