Executions for behaviour:
"1:R0=1 ; x=2"
ARM S+PPO343 "Wse DMBdWW Rfe PosRR DpDatadW PosWR PosRR DpAddrdR DpDatadW" Cycle=Rfe PosRR DpDatadW PosWR PosRR DpAddrdR DpDatadW Wse DMBdWW Relax= Safe=Rfe Wse PosWR PosRR DMBdWW DpAddrdR DpDatadW Prefetch=0:x=F,1:x=W Orig=Wse DMBdWW Rfe PosRR DpDatadW PosWR PosRR DpAddrdR DpDatadW { %x0=x; %y0=y; %y1=y; %z1=z; %a1=a; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | EOR R2,R1,R1 ; MOV R1, #1 | ADD R2, R2, #1 ; STR R1, [%y0] | STR R2, [%z1] ; | LDR R3, [%z1] ; | LDR R4, [%z1] ; | EOR R5,R4,R4 ; | LDR R6, [R5,%a1] ; | EOR R7,R6,R6 ; | ADD R7, R7, #1 ; | STR R7, [%x1] ; Observed 1:R0=1; x=2;
