Test S+PPO335
Executions for behaviour: "1:R0=1 ; x=2 ; y=2"
ARM S+PPO335
"Wse DMBdWW Rfe PosRW PosWR DpAddrdR PosRR DpAddrdR DpDatadW"
Cycle=Rfe PosRW PosWR DpAddrdR PosRR DpAddrdR DpDatadW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWR PosRW PosRR DMBdWW DpAddrdR DpDatadW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRW PosWR DpAddrdR PosRR DpAddrdR DpDatadW
%x0=x; %y0=y;
%y1=y; %z1=z; %a1=a; %x1=x;
 P0            | P1               ;
 MOV R0, #2    | LDR R0, [%y1]    ;
 STR R0, [%x0] | MOV R1, #2       ;
 DMB           | STR R1, [%y1]    ;
 MOV R1, #1    | LDR R2, [%y1]    ;
 STR R1, [%y0] | EOR R3,R2,R2     ;
               | LDR R4, [R3,%z1] ;
               | LDR R5, [%z1]    ;
               | EOR R6,R5,R5     ;
               | LDR R7, [R6,%a1] ;
               | EOR R8,R7,R7     ;
               | ADD R8, R8, #1   ;
               | STR R8, [%x1]    ;
Observed
    1:R0=1; x=2; y=2;
